Thai cancella tutti i voli per l'Europa
THAI Cancels Flights to Pakistan and all European Routes Due to Pakistani Airspace Closure
Thai Airways International Public Company Limited (THAI) announced that its flights to Pakistan have been cancelled due to sudden closure of Pakistani airspace as a result of tension between India and Pakistan.
Flight Lieutenant Pratana Patanasiri, THAI Vice President, Aviation Safety, Security and Standards Department, said that Pakistani airspace closed suddenly due to tension between India and Pakistan. Therefore, THAI has cancelled its flights to Pakistan and flights operated through Pakistani airspace on 27 February 2019, as follows:
- Flights TG341 and TG342 to and from Bangkok-Karachi
- Flights TG345 and TG346 to and from Bangkok-Lahore
- Flights TG349 and TG350 to and from Bangkok-Islamabad
Three flights operate though Pakistani airspace today areas follows:
- Flight TG916 from Bangkok-London
- Flight TG974 from Bangkok-Moscow
- Flight TG926 from Bangkok-Frankfurt
The above-mentioned flights were returned to Bangkok and arrived safely at Suvarnabhumi Airport today. THAI has looked after passengers affected by flight cancellations, in accordance to international standards.
Furthermore, THAI has cancelled the following11 flights to destinations in Europe that were operated on 27 and 28 February 2019, in order to maintain the highest passenger and operational safety standards:
On 27 February 2019:
- Flight TG920 from Bangkok-Frankfurt
On 28 February 2019:
- Flight TG910 from Bangkok-London
- Flight TG924 from Bangkok-Munich
- Flight TG930 from Bangkok-Paris
- Flight TG934 from Bangkok-Brussels
- Flight TG940 from Bangkok-Milan
- Flight TG936 from Bangkok-Vienna
- Flight TG960 from Bangkok-Stockholm
- Flight TG970 from Bangkok-Zurich
- Flight TG950 from Bangkok-Copenhagen
- Flight TG954 from Bangkok-Oslo
The following flights from destinations in Europe to Bangkok on 27 February 2019 have been cancelled:
- Flight TG911 from London-Bangkok
- Flight TG921 from Frankfurt-Bangkok
- Flight TG931 from Paris-Bangkok
- Flight TG941 from Milan-Bangkok
- Flight TG945 from Rome-Bangkok
- Flight TG971 from Zurich-Bangkok
- Flight TG951 from Copenhagen-Bangkok
- Flight TG961 from Stockholm-Bangkok
- Flight TG955 from Oslo-Bangkok
- Flight TG925 from Munich-Bangkok
THAI is monitoring the situation closely in order to properly assess the situation and plans to operate flights on an alternative route that does not pass Pakistan and is now awaiting for airspace authorization.
THAI advises all passengers traveling on the aforementioned flights to check the Company’s announcements and keep abreast of all related news. For information on flight schedules, passengers may check at thaiairways.com or THAI Contact Center at Tel. 0-356-1111, 24-hours a day.
THAI passengers who hold tickets on routes affected by flight cancellation may change their itinerary. Fees and charges will be exempted, and conditions apply.
THAI operates flights to three destinations in Pakistan: one flight per day to Karachi and Lahore and four flights per week to Islamabad on Monday, Wednesday, Friday, and Saturday.
Re: Thai cancella tutti i voli per l'Europa
Il volo di oggi da Malpensa é cancellato, anche altri vettori asiatici hanno più di un problema (Singapore, Air India...)
Diverse rotte ortodromiche da Bangkok verso l'Europa non sfiorano neppure il confine indo-pakistano e per quelle che ci passano sopra basta deviare il tracciato di una manciata di chilometri per evitarlo. Strano che Thai abbia deciso di cancellare i voli di ben due giorni.
Stando al sito Air Italy, la IG931 è semplicemente schedulata con 30 minuti in piu.
Che sf..a, dovrò andare in Thailandia con TG il 14 marzo... Qualcuno sa come mi devo comportare? Si può optare per essere riprotetti con altre compagnie in caso di cancellazione?
Grazie
Grazie
Dubito che tengano ferma a terra mezza flotta per svariate settimane. Sarebbe una catastrofe! Dovranno rimodulare le rotte e gli orari...
Solo non capisco perché loro abbiano problemi a deviare su altri spazi aerei mentre gli altri no, a parte l'allungamento di percorso.
Mauz® ha scritto:Solo non capisco perché loro abbiano problemi a deviare su altri spazi aerei mentre gli altri no, a parte l'allungamento di percorso.
appunto....ad esempio SQ allora che fa? non mi pare abbia annunciato cancellazioni...
Ho letto dal sito TG che hanno ripristinato le normali operazioni di volo, hanno avuto il benestare dalla Cina ad attraversare il loro spazio aereo
Guardando Flightradar24 Sembrerebbe che il TG941 di oggi faccia rotta verso il medio oriente e non via Cina (corridoio URC-KMG)...
Visitano il forum: Bing [Bot], Google [Bot] e 243 ospiti
