UA rumors su rotte in Europa
Da prendere con le pinze, ma posto cmq le indiscrezioni, in passato la fonte è risultata attendibile:
In 2008 United Airlines might start some new international routes. Among them:
Chicago - Moscow. Aeroflot used to fly this route but stopped in 2001, and United holds the dormant route authority for the route, which it obtained in a deal with Pan Am back in 1991. (If United did fly this route, it would probably skip Moscow's Sheremetyevo Airport (SVO) and instead fly to Domodedovo Airport (DME) because its fellow Star Alliance carriers fly there.)
The US-Russia market is currently served by a lot of routes - Delta flies Moscow - Atlanta and Moscow - New York (JFK), and Aeroflot flies Moscow - New York (JFK), Los Angeles, and Washington (IAD).
Chicago - Milan. United used to fly Washington-Milan, but stopped in 2001 after 11/9. If United did fly this route, it would compete with Alitalia.
Chicago - Düsseldorf. United used to fly this route but stopped in 2001. Star Alliance partner Lufthansa flies it with an Airbus A319, but is supposed to upgrade the route to an Airbus A330 in May.
It has also been rumored that United would upgrade some of its Boeing 767-300s, including a switch from a two-class domestic configuration to a three-class international one, and an engine upgrade. These upgraded 767s would be used on the route.
Re: UA rumors su rotte in Europa
Non competerebbe con AZ visto che se ne va... :roll:
Se confermata,significa sempre più STAR a mxp!! 8)
dato che questi rumors risalgono a settembre/ottobre, in merito a Dusseldorf e LH ci hanno azzeccato se si guarda cosa appare tra le nuove tratte:
Dusseldorf-Newark, 7xw con A343
Dusseldorf-Chicago, 6xw con A343
Dusseldorf-Toronto, 6xw con A343
Dusseldorf-Miami, 6xw con A343
E speriamo proprio che azzecchino pure la nostra, per cominciare va bene pure un 763 ricondizionato!
speriamo....
ormai dalla wintr dovrebbe iniziare....speriamo cmq........ :mrgreen:
- AvioTohr
Ma quando si saprà eventualmente con certezza? Comunque una fantastica news (e tratta) se confermata! 8)
Sky, rimane il fatto che non annunceranno nulla per la summer. Mi sembra strano che sia muova UA e non AA per la rotta, anche se un eventuale mini-hub di star a MXP potrebbe giustificare la scelta di UA di operare la tratta. Vedremo come si evolverà la faccenda. Spero vivamente che la tratta venga attivata.
Con la dipartita di AZ, credo che ci siano buone probabilità!BAlorMXP ha scritto:Sky, rimane il fatto che non annunceranno nulla per la summer. Mi sembra strano che sia muova UA e non AA per la rotta, anche se un eventuale mini-hub di star a MXP potrebbe giustificare la scelta di UA di operare la tratta. Vedremo come si evolverà la faccenda. Spero vivamente che la tratta venga attivata.
Le possibilità ci sono, ma per quest'estate, se tutto andasse in porto, il volo su ORD non sarà presente nel network di MXP.
quoto. Bisogna vedere l'evoluzione della presenza di AP a Mxp (tra l'altro sembra che i collegamenti con Fco siano anticipati già a luglio) che garantirebbbe feeder.BAlorMXP ha scritto:Le possibilità ci sono, ma per quest'estate, se tutto andasse in porto, il volo su ORD non sarà presente nel network di MXP.
