Francoforte: molo A plus e sviluppo apt
le news dagli aeroporti non lombardi
Messaggio da leggereda I-Alex » dom 14 giu 2009, 11:54:52
Dopo un po' di mesi sono tornato a fare un giretto turistico a Fra Airport e devo dire che in poco tempo continuano i mega lavori!
La nuova zona commerciale/finanziari sopra la stazione dell'AV è ormai in fase di ultimazione ( almeno 25 gru...), i lavori di demolizione e sbancamento per il nuovo molo A plus sono a buon punto, la zona del Terminal 3 è già stata sbancata e si vedono già alcune costruzioni, i lavori per la taxiway verso la 4' pista sono già in fase avanzata e continuano i lavori di ammodernamento del T1...
Qualche news e foto direttamente dal sito di Fraport :razz:
MOLO A Plus
Current Situation:
The preparations for A-Plus are now ongoing, and some of them have already been completed. Work to excavate the construction pit began in November 2008 and is scheduled to be finished by mid-2009. The details of the plans for the new pier and root section are now being worked out and the remaining construction contracts awarded.
2006 Competition
Competition in mid-2006, decision in late 2006, start of planning by gmp in January 2007
01/ 2007 Preparations
Clearing of the construction site (with moving of infrastructure, e.g. demolition of parking structure P31), partial shutdown of the existing Pier A (e.g. moving walkways and gate areas), replacement measures (e.g. lounge and retail areas) and installation of a new district heat conduit
01/ 2007 Start of apron work
Breakup of apron slabs
Creation of interim aircraft positions
Implementation of apron work in 10 stages
11/ 2008 Start of excavation work
Removal of 260,000 cu.m of soil; bracing work, moving of infrastructure, kickoff of construction site logistics, demolition of the stairwells and passenger bridges at gates A10 and A12, blocking of aircraft positions and gates
03/2009 Start of structural work
Start of structural work on existing buildings, modification of existing building systems
Early 2010 Start of work on façade
mid-2010 Start of work on interiors Start of work on interiors
2012 Start of operations
Pier A-Plus will begin operating when the 2012 summer flight schedule takes effect.
i lavori in corso
il riammodernamento del T1 A
Ecco gli altri grandi interventi
Per le altre foto guardate QUI mentre i progetti li trovate QUI
Renato
Re: Francoforte: molo A plus e sviluppo apt
Messaggio da leggereda Renato » mer 24 giu 2009, 21:03:07
Esisterà un collegamento tramite veicoli automatici tra vecchio e nuovo terminal (al di sotto delle piste)?
Messaggio da leggereda I-Alex » gio 25 giu 2009, 10:09:51
Renato ha scritto:Esisterà un collegamento tramite veicoli automatici tra vecchio e nuovo terminal (al di sotto delle piste)?
sinceramente non saprei... ma considerando che davanti al T1 ci passano i treni AV e S-Bahn credo non sia da tedeschi lasciare il T3 sguarnito... a meno che al T3 non sia prevista un'altra stazione ferroviaria.
Collegare il T1 al T3 per i soli transiti invece lo vedo strano: col nuovo terminal verranno riviste le posizioni della varie alleanze
Torna a “AEROPORTI NEL MONDO”
