Ecco la lista dei capitoli ATA:
ATA Specification 2200
1 *Reserved for Airline Use
2 *Reserved for Airline Use
3 *Reserved for Airline Use
4 *Reserved for Airline Use
5 TIME LIMITS/ MAINTENANCE CHECKS
-00 General
-10 Time Limits
-20 Scheduled Maintenance Checks
-30 & -40 Reserved
-50 Unscheduled Maintenance checks
6 DIMENSIONS AND AREAS
7 LIFTING & SHORING
-00 General
-10 Jacking
-20 Shoring
8 LEVELING & WEIGHING
-00 General
-10 Weighing and Balancing
-20 Leveling
9 TOWING & TAXIING
-00 General
-10 Towing
-20 Taxiing
10 PARKING, MOORING, STORAGE & RETURN TO SERVICE
-00 General
-10 Parking/Storage
-20 Mooring
-30 Return to Service
11 PLACARDS AND MARKINGS
-00 General
-10 Exterior Color Schemes and Markings
-20 Exterior Placards and Markings
-30 Interior Placards
12 SERVICING
-00 General
-10 Replenishing
-20 Scheduled Servicing
-30 Unscheduled Servicing
13 *Unassigned
14 *Unassigned
15 *Unassigned
16 *Unassigned
17 *Unassigned
18 VIBRATION AND NOISE ANALYSIS (HELICOPTER ONLY)
-00 GENERAL -
-10 VIBRATION ANALYSIS
-20 NOISE ANALYSIS
19 *Unassigned
20 STANDARD PRACTICES-AIRFRAME
-90 *Reserved for Airline Use
21 AIR CONDITIONING
-00 General
-10 Compression
-20 Distribution
-30 Pressurization Control
-40 Heating
-50 Cooling
-60 Temperature Control
-70 Moisture/Air Contaminant
22 AUTO FLIGHT
-00 General
-10 Autopilot
-20 Speed-Attitude Correction
-30 Auto Throttle
-40 System Monitor
-50 Aerodynamic Load Alleviating
23 COMMUNICATIONS
-00 General
-10 Speech Communications
-15 SATCOM
-20 Data Transmission and Automatic Calling
-30 Comfort
-40 Interphone
-50 Audio Integrating
-60 Static Discharging
-70 Audio & Video Monitoring
-80 Integrated Automatic
24 ELECTRICAL POWER
-00 General
-10 Generator Drive
-20 AC Generation
-30 DC Generation
-40 External Power
-50 AC Electrical Load Distribution
-60 DC Electrical Load Distribution
25 EQUIPMENT/FURNISHINGS
-00 General
-10 Flight Compartment
-20 Passenger Compartment
-30 Galley
-40 Lavatories
-50 Additional Compartments
-60 Emergency
-70 Available
-80 Insulation
26 FIRE PROTECTION
-00 General
-10 Detection
-20 Extinguishing
-30 Explosion Suppression
27 FLIGHT CONTROLS
-00 General
-10 Aileron & Tab
-20 Rudder & Tab
-30 Elevator & Tab
-40 Horizontal Stabilizer
-50 Flaps
-60 Spoiler, Drag Devices and Variable Aerodynamic Fairings
-70 Gust Lock & Dampener
-80 Lift Augmenting
28 FUEL
-00 General
-10 Storage
-20 Distribution
-30 Dump
-40 Indicating
29 HYDRAULIC POWER
-00 General
-10 Main
-20 Auxiliary
-30 Indicating
30 ICE AND RAIN PROTECTION
-00 General
-10 Airfoil
-20 Air Intakes
-30 Pitot and Static
-40 Windows, Windshields and Doors
-50 Antennas and Radomes
-60 Propellers/Rotors
-70 Water Lines
-80 Detection
31 INDICATING/RECORDING SYSTEMS
-00 General
-10 Instrument & Control Panels
-20 Independent Instruments
-30 Recorders
-40 Central Computers
-50 Central Warning Systems
-60 Central Display Systems
-70 Automatic Data Reporting Systems
32 LANDING GEAR
-00 General
-10 Main Gear and Doors
-20 Nose Gear and Doors
-30 Extension and Retraction
-40 Wheels and Brakes
-50 Steering
-60 Position and Warning
-70 Supplementary Gear
33 LIGHTS
-00 General
-30 Cargo and Service Compartments
-40 Exterior
-50 Emergency Lighting
34 NAVIGATION
-00 General
-10 Flight Environment
-20 Attitude & Direction
-30 Landing and Taxiing Aids
-40 Independent Position Determining
-50 Dependent Position Determining
-60 Flight Management Computing
35 OXYGEN
-00 General
-10 Crew
-20 Passenger
-20 Passenger
-30 Portable
36 PNEUMATIC
-00 General
-10 Distribution
-20 Indicating
37 VACUUM
-00 General
-10 Distribution
-20 Indicating
38 WATER/WASTE
-00 General
-10 Potable
-20 Wash
-30 Waste Disposal
-40 Air Supply
39 *Unassigned
40 *Unassigned
41 WATER BALLAST
-00 General
-10 Storage
-20 Dump
-30 Indication
42 *Unassigned
43 *Unassigned
44 CABIN SYSTEMS
-00 General
-10 Cabin Core System
-20 Inflight Entertainment System
-30 External Communication System
-40 Cabin Mass Memory System
-50 Cabin Monitoring System
-60 Miscellaneous Cabin System
45 CENTRAL MAINTENANCE SYSTEM
-00 General
-5 thru -19 CMS/Aircraft General
-20 thru -49 CMS/Airframe Systems
-45 Central Maintenance System
-50 thru -59 CMS/Structures
-60 thru -69 CMS/Propellers
-70 thru -89 CMS/Power Plant
45INFORMATION SYSTEMS
-00 General
-10 Airplane General Information Systems
-20 Flight Deck Information Systems
-30 Maintenance Information Systems
-40 Passenger Cabin Information Systems
-50 Miscellaneous Information Systems
47 *Unassigned
48 *Unassigned
49 AIRBORNE AUXILIARY POWER
-00 General
-10 Power Plant
-20 Engine
-30 Engine Fuel and Control
-40 Ignition/Starting
-50 Air
-60 Engine Controls .
-70 Indicating
-80 Exhaust
-90 Oil
50 Cargo and Accessory Compartments
-00 General
-10 Cargo Compartments
-20 Cargo Loading Systems
-30 Cargo Related Systems
-40 Available
-50 Accessory
-60 Insulation
51 Standard Practices, General
-00 General
-10 Investigation, Cleanup and Aerodynamic Smoothness
-20 Processes
-30 Materials
-40 Fasteners
-50 Support of Airplane for Repair and Alignment Check Procedures
-60 Control-Surface Balancing
-70 Repairs
-80 Electrical Bonding
52 DOORS
-00 General
-10 Passenger/Crew
-20 Emergency Exit
-30 Cargo
-40 Service and Miscellaneous
-50 Fixed Interior
-60 Entrance Stairs
-70 Monitoring and Operation
-80 Landing Gear
53 FUSELAGE
-00 General
-10 thru -90 (As Required) Fuselage Sections
54 NACELLES/PYLONS
-00 General
-10 thru -40 (As Required) Nacelle Section
-50 thru -80 (As Required) Pylon
55 STABILIZERS
-00 General
-10 Horizontal Stabilizer or Canard
-20 Elevator
-30 Vertical Stabilizer
-40 Rudder
56 WINDOWS
-00 General
-30 Door
-40 Inspection and Observation
57 WINGS
-00 General
-10 Center Wing
-20 Outer Wing
-30 Wing Tip
-40 Leading Edge and Leading Edge Devices
-50 Trailing Edge Trailing Edge Devices
-60 Ailerons and Elevons
-70 Spoilers
-80 (as required)
-90 Wing Folding System
58 *Unassigned
59 *Reserved for Airline Use
60 STANDARD PRACTICES - PROPELLER/ROTOR
61 PROPELLERS/PROPULSION
-00 General
-10 Propeller Assembly
-20 Controlling
-30 Braking
-40 Indicating
-50 Propulsor Duct
62 ROTOR(S)
-00 General
-10 Rotor blades
-20 Rotor head(s)
-30 Rotor Shaft(s)/Swashplate Assy(ies)
-40
63 ROTOR DRIVE(S)
-00 General
-10 Engine/Gearbox couplings
-20 Gearbox(es)
-30 Mounts, attachments
-40 Indicating
64 TAIL ROTOR
-00 General
-10* Rotor blades
-20* Rotor head
-30 Available
-40 Indicating
65 TAIL ROTOR DRIVE
-00 General
-10 Shafts
-20 Gearboxes
-30 Available
-40 Indicating
66 FOLDING BLADES/PYLON
-00 General
-10 Rotor blades
-20 Tail pylon
-30 Controls and Indicating
67 ROTORS FLIGHT CONTROL
-00 General
-10 Rotor
-20 Anti-torque Rotor control (Yaw control)
-30 Servo-control System
68 *Unassigned
69*Unassigned
70 STANDARD PRACTICES - ENGINES
71 POWER PLANT
-00 General
-10 Cowling
-30 Fireseals
-40 Attach Fittings
-50 Electrical Harness
-60 Air Intakes
-70 Engine Drains
72 ENGINE TURBINE/TURBO PROP DUCTED FAN/UNDUCTED FAN
-00 General
-10 Reduction Gear, Shaft Section (Turbo-Prop and/or Front Mounted Gear Driven Propulsor)
-20 Air Inlet Section
-30 Compressor Section
-40 Combustion Section
-50 Turbine Section
-60 Accessory Drives
-70 By-pass Section
-80 Propulsor Section (Rear Mounted)
73 ENGINE FUEL AND CONTROL
-00 General
-10 Distribution
-20 Controlling
-30 Indicating
74 IGNITION
-00 General
-10 Electrical Power
-20 Distribution
-30 Switching
75 AIR
-00 General
-10 Engine Anti-Icing
-20 Cooling
-30 Compressor Control
-40 Indicating
76 ENGINE CONTROLS
-00 General
-10 Power Control
-20 Emergency Shutdown
77 ENGINE INDICATING
-00 General
-10 Power
-20 Temperature
-30 Analyzers That
-40 Integrated Engine Instrument Systems
78 EXHAUST
-00 General
-10 Collector/Nozzle
-20 Noise Suppressor
-30 Thrust Reverser
-40 Supplementary Air
79 OIL
-00 General
-10 Storage
-20 Distribution
-30 Indicating
80 STARTING
-00 General
-10 Cranking
81 TURBINES
-00 General
-10 Power Recovery
-20 Turbo-Supercharger
82 WATER INJECTION
-00 General
-10 Storage
-20 Distribution
-30 Dumping and Purging
-40 Indicating
83 ACCESSORY GEAR-BOXES
-00 General
-10 Drive Shaft Section
-20 Gearbox Section
84 Propulsion Augmentation
-00 General
-10 Jet Assist Takeoff
85 *Unassigned
86 *Unassigned
87 *Unassigned
88 *Unassigned
89 *Unassigned
90 *Unassigned
91 CHARTS
92 *Unassigned
93 *Unassigned
94 *Unassigned
95 *Reserved for Airline Use
96 *Reserved for Airline Use
97 WIRING REPORTING
-00-00 General
-01-00 Zone 100 Fuselage Lower
-02-00 Zone 200 Fuselage Top
-03-00 Zone 300 Stabilizers
-04-00 Zone 400 Nacelles-Pylons
-05-00 Zone 500 Left Wing
-06-00 Zone 600 Right Wing
-07-00 Zone 700 Landing Gear Compartment
-08-00 Zone 800 Doors
-09-00 Zone 900 Lavatories & Galleys
-20-00 Electrical Standard Items/Practices
-21-00 Air Conditioning - General
-21-10 Compression
-21-20 Distribution
-21-30 Pressurization Control
-21-40 Heating
-21-50 Cooling
-21-60 Temperature Control
-21-70 Moisture/Air Contaminant Control
-22-00 Auto Flight - General
-22-10 Autopilot
-22-20 Speed - Attitude Correction
-22-30 Auto Throttle
-22-40 System Monitors
-22-50 Aerodynamic Load Alleviating
-23-00 Communications - General
-23-10 Speech Communications
-23-15 SATCOM
-23-20 Data Transmission and Automatic Calling
-23-30 Passenger Address, Entertainment and Comfort
-23-40 Interphone
-23-50 Audio Integrating
-23-60 Static Discharging
-23-70 Audio and Video Monitoring
-23-80 Integrated Automatic Tuning
-24-00 Electrical Power - General
-24-10 Generator Drive
-24-20 AC Generation
-24-30 DC Generation
-24-40 External Power
-24-50 AC Electrical Load Distribution
-24-60 DC Electrical Load Distribution
-25-00 Equipment/Furnishings - General
-25-10 Flight Compartment
-25-20 Passenger Compartment
-25-30 Galley
-25-40 Lavatories
-25-60 Emergency
-25-80 Insulation
-26-00 Fire Protection - General
-26-10 Detection
-26-20 Extinguishing
-26-30 Explosion Suppression
-27-00 Flight Controls - General
-27-10 Aileron & Tab
-27-20 Rudder & Tab
-27-30 Elevator & Tab
-27-40 Horizontal Stabilizer
-27-50 Flaps
-27-60 Spoiler, Drag Devices and Variable Aerodynamic Fairings
-27-70 Gust Lock & Dampener
-27-80 Lift Augmenting
-28-00 Fuel - General
-28-10 Storage
-28-20 Distribution
-28-30 Dump
-28-40 Indicating
-29-00 Hydraulic Power - General
-29-10 Main
-29-20 Auxiliary
-29-30 Indicating
-30-00 Ice and Rain Protection - General
-30-10 Airfoil
-30-20 Air Intakes
-30-30 Pitot and Static
-30-40 Windows, Windshields and Doors
-30-50 Antennas And Radomes
-30-60 Propellers/Rotors
-30-70 Water Lines
-30-80 Detection
-31-00 Indicating/Recording Systems - General
-31-10 Instrument and Control Panels
-31-20 Independent Instruments
-31-30 Recorders
-31-40 Central Computers
-31-50 Central Warning Systems
-31-60 Central Display Systems
-31-70 Automatic Data Reporting Systems
-32-00 Landing Gear- General
-32-10 Main Gear and Doors
-32-20 Nose Gear and Doors
-32-30 Extension and Retraction
-32-40 Wheels and Brakes
-32-50 Steering
-32-60 Position And Warning
-32-70 Supplementary Gear
-33-00 Lights - General
-33-10 Flight Compartment
-33-20 Passenger Compartment
-33-30 Cargo and Service Compartments
-33-40 Exterior
-33-50 Emergency Lighting
-34-00 Navigation - General
-34-10 Flight Environment Data
-34-20 Attitude & Direction
-34-30 Landing and Taxiing Aids
-34-40 Independent Position Determining
-34-50 Dependent Position Determining
-34-60 Flight Management Computing
-35-00 Oxygen - General
-35-10 Crew
-35-20 Passenger
-35-30 Portable
-36-00 Pneumatic - General
-36-10 Distribution
-36-20 Indicating
-37-00 Vacuum - General
-37-10 Distribution
-37-20 Indicating
-38-00 Water/Waste - General
-38-10 Potable
-38-20 Wash
-38-30 Waste Disposal
-38-40 Air Supply
-44-00 Cabin Systems - General
-44-10 Cabin Core System
-44-20 In-flight Entertainment System
-44-30 External Communication System
-44-40 Cabin Mass Memory System
-44-50 Cabin Monitoring System
-44-60 Miscellaneous Cabin System
-45-00 Central Maintenance System (CMS) General
-45-05 CMS/Aircraft General
-45-20 CMS/Airframe Systems
-45-45 Central Maintenance System
-45-50 CMS/Structures
-45-60 CMS/Propellers
-45-70 CMS/Power Plant
-46-00 Information Systems - General
-46-10 Airplane General Information Systems
-46-20 Flight Deck Information Systems
-46-30 Maintenance Information Systems
-46-40 Passenger Cabin Information Systems
-46-50 Miscellaneous Information Systems
-49-00 Airborne Auxiliary Power - General
-49-10 Power Plant
-49-20 Engine
-49-30 Engine Fuel And Control
-49-40 Ignition And Starting
-49-50 Air
-49-60 Engine Controls
-49-70 Indicating
-49-80 Exhaust
-49-90 Oil
-50-00 Cargo And Accessory Compartments General
-50-10 Cargo Compartments
-50-20 Cargo Loading Systems
-50-30 Cargo Related Systems
-50-40 Available
-50-50 Accessory Compartments
-50-60 Insulation
-52-00 Doors - General
-52-10 Passenger/Crew
-52-20 Emergency Exit
-52-30 Cargo
-52-40 Service
-52-50 Fixed Interior
-52-60 Entrance Stairs
-52-70 Door Warning
-52-80 Landing Gear
-53-00 Fuselage - General
-54-00 Nacelles/Pylons - General
-54-10 Nacelle Section
-54-50 Pylon
-55-00 Stabilizers - General
-55-10 Horizontal Stabilizer or Canard
-55-20 Elevator
-55-30 Vertical Stabilizer
-55-40 Rudder
-56-00 Windows - General
-56-10 Flight Compartment
-56-20 Passenger Compartment
-56-30 Door
-56-40 Inspection and Observation
-57-00 Wings - General
-57-10 Center Wing
-57-20 Outer Wing
-57-30 Wing Tip
-57-40 Leading Edge and Leading Edge Devices
-57-50 Trailing Edge and Trailing Edge Devices
-57-60 Ailerons
-57-70 Spoilers
-57-90 Wing Folding System
-61-00 Propellers/Propulsors - General
-61-10 Propeller Assembly
-61-20 Controlling
-61-30 Braking
-61-40 Indicating
-61-50 Propulsor Duct
-62-00 Rotors
-63-00 Rotor Drives
-64-00 Tail Rotor
-65-00 Tail Rotor Drive
-66-00 Folding Blades/Pylon
-67-00 Rotors Flight Control
-71-00 Power Plant - General
-71-10 Cowling
-71-20 Mounts
-71-30 Fire seals
-71-40 Attach Fittings
-71-50 Electrical Harness
-71-60 Air Intakes
-71-70 Engine Drains
-72-00 Engine Turbine/Turbo Prop Ducted Fan/Unducted Fan
-72-10 Reduction Gear, Shaft Section (Turbo-Prop and/or Front Mounted Gear
Driven Propulsor)
-72-20 Air Inlet Section
-72-30 Compressor Section
-72-40 Combustion Section
-72-50 Turbine Section
-72-60 Accessory Drives
-72-70 By-pass Section
-72-80 Propulsor Section (Rear Mounted)
-73-00 Engine Fuel And Control - General
-73-10 Distribution
-73-20 Controlling
-73-30 Indicating
-74-00 Ignition - General
-74-10 Electrical Power Supply
-74-20 Distribution
-74-30 Switching
-75-00 Air - General
-75-10 Engine Anti-Icing
-75-20 Cooling
-75-30 Compressor Control
-75-40 Indicating
-76-00 Engine Controls - General
-76-10 Power Control
-76-20 Emergency Shutdown
-77-00 Engine Indicating - General
-77-10 Power
-77-20 Temperature
-77-30 Analyzers
-77-40 Integrated Engine Instrument Systems
-78-00 Exhaust - General
-78-10 Collector/Nozzle
-78-20 Noise Suppressor
-78-30 Thrust Reverser
-78-40 Supplementary Air
-79-00 Oil - General
-79-10 Storage
-79-30 Indicating
-80-00 Starting - General
-80-10 Cranking
98 *Reserved for Airline Use
99 *Unassigned
100 *Do not use
101 *Do not use
102 *Do not use
103 *Do not use
104 *Do not use
105 *Do not use
106 *Do not use
107 *Do not use
108 *Do not use
109 *Do not use
110 *Do not use
111 *Do not use
112 *Do not use
113 *Do not use
114 *Do not use
115 Flight Simulator Systems
Capitoli ATA
- Aeroplanaro
- Contatta:
Capitoli ATA
Francesco
Mai ti torrese a bidere, né tue né s’annada mala!
Re: Capitoli ATA
Hei sapete tutti di che si tratta?
Io sinceramente non ci capisco niente!!
C'è qualche anima pia che può tradurre in chiaro questa list?
Grazie!!!
Grazie!!!
- Aeroplanaro
- Contatta:
Re: Capitoli ATA
Questa è la lista dei capitoli ATA ovvero, quando cercherai l'Impianto di Condizionamento lo troverai sempre al capitolo 21.mxp98 ha scritto: C'è qualche anima pia che può tradurre in chiaro questa list?
Grazie!!!
Gli Impianti degli aeromobili vengono suddivisi per capitolo ( la lista è autoesplicativa)
ed è comune per tutti dal Cessna 172 allo Space Shuttle
Francesco
Re: Capitoli ATA
Ho potuto constatare,cosi come la sezione flight control è e sarà sempre al capitolo 27 suppongo.
Grazie
Grazie
